How far into tranny should driveshaft go?
I'm swapping my M6 for a T400 and I have a driveshaft setup for the T400. To get it in I had to push it all the way in the tranny, unhook my LCA's and pull the rear end back then hook it to the rear. My LCA's went back in. It just seemed longer compared to when I changed my stocker. I jsut slide it in the tranny then pulled it back into the yoke.
Re: How far into tranny should driveshaft go?
I know on some of the turbo 400's the yoke bolted to the output shaft of the trans thats how mine was the trans came from a truck.but that might not be the reason,it may be that the yoke might not be going in all the way,Mines machined on my new driveshaft.U should be ok as long as there is some room for the driveshaft to move in and out of the trans.By the way brad i mailed u a check today
