Moser 10 bolt
Old Nov 24, 2008 | 12:20 PM
boilertwinkie's Avatar
Default Moser 10 bolt
I have a spare new auburn pro and was thinking of doing a higher gear rebuild. I beleive my axles are the weak link, but have heard mixed opinions on the moser axles with c clip eliminators. Thoughts?
Old Nov 24, 2008 | 12:21 PM
Default Gears
How much quieter are motive gears than richmond. I have some richmond gears and they can get annoying after some time.
Old Nov 24, 2008 | 01:10 PM
FirstYrLS1Z's Avatar
Active Streak: 30 Days
the axles are not the weak link,no matter what internals(gears or carriers) you use for our 7.5/7.625 10 bolt,those internals are still going to be the 'weak link'
Old Nov 24, 2008 | 02:06 PM
jetlag's Avatar
Best post ever. ^
Old Nov 24, 2008 | 02:22 PM
the_merv's Avatar
Veteran: Air Force
How much power are you putting out? I had one of them Auburn Pro Series, it held up with my LT1 Build, but I blew the Clutches out of it the first time to the Track with my 402 Build.
Old Nov 24, 2008 | 03:43 PM
gold98Z28's Avatar
i blew the clutches out of my pro series unit first time out too...... ive broke several on a m6 car. never killed the gears tho, twisted an axle when i killed the last unit also. what tranny you running. you can get by with an auto for along time as long as you dont trans brake it....... i have a new in box auburn pro series unit i think im gonna sell since ive convinced myself it will never hold up. haha
Old Nov 26, 2008 | 10:29 AM
Im thinking about doing a stall and putting a 3.42 gear in with moser axles. The car is a A4 with 340rwhp.
Old Nov 26, 2008 | 07:02 PM
EPP's Avatar
EPP
I'd go with these axles from Moser. http://www.exoticperformanceplus.com...html?item=1341 I wouldn't invest a lot of money into the rear, as it will eventually break no matter how much you try to beef it up. Bob
Old Nov 27, 2008 | 10:59 AM
thanks for the info when i get everything together Ill contact you about some shafts
