Just need opinions on a new rear
Old 11-26-2008, 12:03 AM
booch137's Avatar
Default Just need opinions on a new rear
I have a '99 Z a4 and race street once in a while but this is mostly your basic DD. I want to change the stock rear from 3.23's to 3.73 but nothing more agressive than that. I think I want to keep a LSD considering this isn't a track car and a posi around town is not the best idea. Any opinions on what brand of rear to go with or even if i need to change the rear or just the gears? All opinions are welcome.
Also there's the option of stalls but I'm not sure which I really want to do. Is it safe to say that a stall is most like an automatic clutch?
Old 11-26-2008, 04:16 AM
EPP
EPP's Avatar
Put a 12 bolt into a early Chevelle, Nova, Camaro, etc and you can beat the crap out of it, and not hurt anything. Put one into one of our cars with a torque arm, make a couple 4000 to 5000 dragstrip launches, and I can just about guarantee you'll pick up gear noise. If it is a drag only car, you'll never know or care about the gear noise. Drive your car home from the track, and the noise will drive you nuts. I feel the torque arm stresses the 12 bolt housing, causing distortion. We have never seen this happen with the 9 inch housing.
Exotic Performance Plus strongly recommends the Moser nine inch. This rear is even tougher than the Moser 12 bolt, and the horsepower of the late model F Body cars keeps escalating every year, which requires a very strong rear. With the recent introduction of the 6.2L GM aluminum block and the excellent flowing 6.2 litre heads, the horsepower of these cars is going to just keep climbing at a very fast pace.The nine inch will handle the power, plus we prefer the way the torque arm is bolted to the nine inch in the same way the oem rear-end is attached. (This is the only good thing about the stock 10 bolt...) The Moser 12 bolt uses four short bolts to attach the torque arm, and they have a habit of loosening up, even when loc-tite is used. Why the nine inch is stronger than the 12 bolt. The 9-inch has an internal rear-pinion support that also supports the gear end of the pinion to limit gear deflection under high torque loads. This seems to be the major reason why the 9 inch doesn't start whining after high rpm clutch dumps, when the 12 bolt will pick up noise.The 9-inch locates its pinion gear lower on the ring gear to improve tooth contact, than the 12 bolt does.The 9-inch has a 0.125-inch larger ring-gear diameter and internal pinion support than the 12 bolt does. This is not much of a difference, but it is worth noting.
Here is a link to the rear I recommend.
http://www.exoticperformanceplus.com....html?item=145 Bob
Old 11-26-2008, 11:33 AM
booch137's Avatar
Thanks for the info on that Bob. And from the research I've done around here the Moser 9 definitely seems to be the way to go.
Old 11-26-2008, 02:15 PM
booch137's Avatar
Anyone have any opinions on stalls?
Old 11-26-2008, 06:58 PM
EPP
EPP's Avatar
Thumbs up
A Vigilante 3000-3200 rpm stall converter is a good way to go. Bob
Old 11-27-2008, 05:30 PM
solo21's Avatar
I went with a 12 bolt rear end but just cause I caught a really good deal on the street, its a good strong rear, but Bob is right after a few hard launches I picked up a winding noise, and it drives me nuts, thats why when I cruise it I turn up the stereo LOL.....anyways If I was to buy a brand new one I would definetly go with the 9".....for an extra couple hundred you will have a stronger rear and from what I heard will ride smooth with no noises......
Old 11-27-2008, 09:34 PM
booch137's Avatar
Sounds good. Time to start saving then
