are all GM gears the same?
Also, just out of curiousity, I am stuck b/w 3.73 3.9 4.10. What are the gives and takes? I've heard the 4.10 is weaker than the 3.73
I'd go 4.10s in a 6-spd and 3.42 with an Auto. The rumor that 4.10s are weaker is simply not true. Of course with more torque multiplication, you will have more of a chance of breaking the gears. That is true any time you use a steeper gear ratio.
A shop down the road said they would do it for 250.
Pretty cheap piece of mind for a shop with a good reputation.
My main concern was the install kit with pinion bearings. summit had a set listed that said up to 98. Come to find out it was just a listing that needed updated. I had thought it would work but wasn't sure.
So, to delay my eventual 12bolt swap, I am using the 3.73's and feel confident they will last, because I don't run DR's, I don't dog on the car anymore, and it doesn't get out much anymore. Took 120k to cause a fail in the rear.....
Not bad!
I twisted the pinion shaft...... never thought that would be the part to fail!
