Used axles
Old Dec 19, 2008 | 10:11 AM
RsSean's Avatar
Default Used axles
Hey would there be any problems using used Moser axles out of another rear end?
I know if you used a used ring and pinion it could cause a whine. Cause of the pattern that was wore into the gears.
Old Dec 19, 2008 | 11:03 AM
Harley-Davidson88's Avatar
As long as they are straight/true and fit your application, you will have no problems.
Old Dec 19, 2008 | 11:22 AM
Jawsgear's Avatar
IF they are not damaged there is no reason why you could not use them. Also I assume they are from the same a year range vehicle.
Jeff
Old Dec 19, 2008 | 07:18 PM
RsSean's Avatar
From what I know they are just take outs, I should be getting pics soon. Yeah they came out of a 4th gen f-body.
Thanks guys for the help.
