posi trac
posi trac
I had a question?Is the zexel torsen diferential they sell at tbyrne is good?Will both tires hook up or will one let go when you start to get some traction? Because mine had 2.73 and i changed them to 3.73 but got a regular carrier and need a positraction and its for 99dollars
Re: posi trac
O ok.I was wondering if it is the same as the one it had before whith small springs or is it the one with the s springs?Is it worth buying?
