Will rtv sealer work?
Old Dec 10, 2008 | 03:54 PM
stingr's Avatar
Default Will rtv sealer work?
I was thinking about using rtv sealer in between the carrier and the housing on a nine inch rear to seal the oil in and prevent drips. Will this work or is there something better to use?
Old Dec 10, 2008 | 04:21 PM
Kingc8r's Avatar
I don't see why not, have you tried a search? Called the company you bought the 9 inch from? I'm sure someone will let you know for sure
Old Dec 10, 2008 | 04:24 PM
BMR Tech2's Avatar
LS1Tech Premium Sponsor
Yes it will work.
__________________
T.C.
Sales Pro
BMR Suspension
(813) 986-9302
Like us on Facebook!
Old Dec 10, 2008 | 05:01 PM
LS1-450's Avatar
Originally Posted by BMR Sales
Yes it will work.
+2, It works very well
Old Dec 10, 2008 | 05:44 PM
jimmyblue's Avatar
Moderator
It worked poorly for me, I RTV'd the gasket to my
MAC cover and the thing wept after install (even
gave it a full day to set up before install), when
I pulled the cover the gasket that had been RTV'd
to the cover just fell right off. I believe I was using
Permatex high temp red.
I am a fan of the "liquid copper" type gasket
sealant myself, that stuff never seems to give up.
Used that on the second pass and no weepage.
Old Dec 10, 2008 | 06:01 PM
MrElectric03's Avatar
I used clear rtv but was told after to use black rtv, so when I change the oil ill switch to black
Old Dec 10, 2008 | 06:49 PM
Kevin97ss's Avatar
All RTV is not created equall. There are many different mixtures for a reason, each has a specific purpose.
With that said, ultra grey is your best bet for diffs, either covers or chunks.
http://www.permatex.com/products/Aut...sket_Maker.htm
Old Dec 10, 2008 | 08:48 PM
wrd1972's Avatar
I assume you mean the gear case and attaching it to the housing. Yes use RTV as opposed to a gasket which will leak.
Gray permatex is awesome and what I run.
Old Dec 10, 2008 | 09:00 PM
CTSmechanic's Avatar
2302 fel pro gasket and High temp RTV... Copper or black.
Old Dec 10, 2008 | 09:06 PM
ksk1980's Avatar
Ive always used the black RTV sealer on my Toyota rear ends (same stlye as a 9") never had a leak and i swamped the **** outta it so I'd deff. say the black works good. just make sure to get a good bead and let it set up b4 filling (thats what i always did w/o any issues to this day.
Old Dec 11, 2008 | 12:51 PM
jmm98LS1's Avatar
I use "Right Stuff" and have never had a leak. The stuff is amazing, you don't even have to let it set up before filling with oil.
Old Dec 11, 2008 | 04:38 PM
03 BUSA's Avatar
Why does no one like gaskets? I am using a steel gasket that I put a little rtv on both sides but car won't be running till spring so I won't know if it leaks till then.
