LS1 rear in LT1 questions
Old 01-10-2009, 12:32 AM
za355tx's Avatar
Default LS1 rear in LT1 questions
Are there any differences between a 3 channel rear end from an LS1 and a 3 channel LT1 rear end? Does anything special need to happen to run a 3 channel rear end from an LS1 car in an LT1 car? Thanks, Zach
Old 01-10-2009, 01:19 AM
jetlag's Avatar
As long as they have both 3 chan, it will work.
Old 01-10-2009, 01:32 AM
za355tx's Avatar
Cool thanks. I thought so but I wanted to be sure before I buy this one I'm gonna look at tomorrow. I appreciate the quick help.
Zach
Old 01-10-2009, 11:31 PM
robsquikz28's Avatar
it will work
Old 01-13-2009, 12:39 AM
jester1614's Avatar
when i swapped mine i swapped the axles over from my lt1 rear end. i have heard on here that the axle lenghts are different but could not get that completely figured out so i swapped anyway. may as well crack the case and put new fluid in it and have the install checked.
but it bolts right up. i swapped in mid nov
Old 01-13-2009, 07:48 AM
93_z28's Avatar
you need to swap th ls1 brakes as well.the lt1 breaks wont bolt up.
