My Moser 9" is leaking at the axle.
Old 06-18-2009, 08:30 PM
98Camarod's Avatar
Yeah I went digging. So basically RTV all the edges on the bearing and the press ring?
Old 06-19-2009, 08:17 AM
2002_z28_m6's Avatar
Originally Posted by BlackDuk98
I have these ball bearing ones also. From what I heard, the taper bearings require a different diameter housing ends to use them. I was told this from a local rear end builder. From what he said, they don't like turns, so no more getting sideways and they last about 3000 miles before they leak. I'm in the same boat as probably 90% of people w/ these brand diffs. The info was never offered.......
They both have the same O.D. But the tapered bearings and the rollers are different as an offset where they bottom out on the axle. I put mine together with ball bearings and my rotors hit my caliper mounts like the axles were 1/8" too long. I changed to the tapers and they fit perfect. I hear the tapered are better anyways. They last longer and dont leak.
Old 06-20-2009, 06:10 PM
DAVESS02's Avatar
Where are you guys getting the tapered bearings from? Part #'s/brand please for future reference, Thanks!
Old 06-21-2009, 12:29 AM
roy
roy's Avatar
All Concerned
If you have a Moser 9inch housing that came with ball bearing axle bearings, then you are stucked with ball bearing axle bearings. You would have to cut off your old axle ends and get a new set of axle ends for the bigger roller bearings. This will include new axles also.
I have talked extensively with Moser Engineering about this and there is no quick and easy fix.
Old 06-24-2009, 09:30 PM
Mikey 97Z M6's Avatar
Originally Posted by Mikey 97Z M6
Haven't had any leaks yet.
Well I think I jinxed myself on this one. Jacked up the car today to start installing some braided stainless fuel line, and low and behold the dreaded oil splatter on the inside of the PS wheel,,,,, Faaawwwwk. Pulled the axle out and the damn cheap POS seal blew out of the bearing and spewed grease/oil everywhere. I'm replacing the bearing with a Napa version and also installing an inside seal for good measure. Now I wonder how long the DS bearing will last before it too decides to take a crap.
FWIW, my axles/bearings were supplied by Moser, but the housing is a Quick Performance. Uses the same interal stuff as Moser, even the axles are the identical lengths etc..
Napa Part Numbers:
Bearing = 88128-R
Inside Seal = 15142
Mike
Old 07-01-2009, 11:04 PM
Jimmard's Avatar
Napa Part Numbers:
Bearing = 88128-R
Inside Seal = 15142
Mike
Now are those bearings and seals somewhat universal meaning that they'll fit in the average moser 9". My bearings are bad and the seals are leaking and I dont want to use the same bearings and seals that moser supplied me with. Mine is a 9" 31 spline axles and a trutrac if that changes anything...
Old 07-02-2009, 12:48 AM
the_merv's Avatar
My driver's side is leaking too in my Moser..I noticed it the other day..it dribbled all over the inside of my Rim.
Something else to get too eventually..
Old 07-02-2009, 07:13 AM
Moser Engineering's Avatar
The reason why we have used and still use the o-ring bearing is that if someone has cut and narrowed their own housing and messed up or totally cut out the seal area in the housing end the o-ring bearing is a way of keeping the diff fluid from leaking.
We sell axles with the o-ring bearing and the Napa 88128RA (our part number is 9508M) for the same price. It isn’t a matter of the cost of the bearing for us but to make sure that the customer has some kind of seal for the diff fluid.
There are a couple of reasons why you can't use the tapered bearing on a ball bearing axle. The bearing spacing on the axle is different for the two different bearings. The inside diameters of the bearings are different so likewise the bearing seat diameter on the axle is different. The outside diameter on the bearings are the same so the housing end is the same for either bearing.
We typically use the ball bearing set up because it is the most common. The tapered bearing is primarily used in off road applications.
Old 07-02-2009, 12:00 PM
Unless you speciall ordered your Moser with specific bearing ends, then yes they are the same. Moser and QP use pretty much the same ends on their 9" housings, not sure about the MWC housings.
FWIW, that bearing was 37.00 and the seal was only about 7.00. IMO that inner seal is well worth the added insurance. Had I known this before hand, I would have installed the inner seal when I assembled the housing/axles.
Mike
Old 07-02-2009, 11:36 PM
Jimmard's Avatar
Well I replaced the seal and bearing today with those napa parts. Only downside I saw was the bearing said MADE IN CHINA right on the box . Where can I order a high quality bearing (including part #s) if I ever have issues with this bearing?
Old 07-03-2009, 09:44 AM
cam
cam's Avatar
Then why do all factory 9" and other bolt in axle retention offerings come from the factory with taper bearings? Heck even Lincolns have taper bearings... 9 bolt Australian... taper bearings...
Old 07-03-2009, 01:49 PM
  #32
roy
roy's Avatar
Cam, not all factory 9inchs came with tapered bearings. The majority was ball bearing. The roller bearing was used in large cars and pickups.
Since I hate typing , here is a cut and paste to explain it.
From Kevin's stang and Malibu racing
for the nine inch (as assembled by Ford)there are 3 different bearings- one small and two large. The two large are the same size ( I.D. / O.D specs), but different types of bearings- one is the traditional sealed ball bearing, while the other is the oil bathed roller bearing and race type.The eight inch and most nine inch housings used the small bearing- including the 31 spline CJ cars, Mustang Hi-performance etc.. This bearing was of the sealed ball bearing type, # RW207CCRA (specs: 1.378" I.D., 2.8246" O.D. by 0.8449" width). Early Galaxies and Broncos and some mid 70's Torinos used the large type sealed ball bearing, which meant they had a large tube housing end, bearing # 88128-RA (specs: 1.5312" I.D., 3.1496" O.D. by width). The second type of large bearing (roller type) was used in later pickups and larger Ford cars, bearing # A20 (specs. 1.530" I.D., 3.1530" O.D.), the seal was on outside of bearing. Because of the two different size bearings used in the 9 inch, there are also two (actually three) different backing plate mounting patterns as well. The standard small bearing has an approximately 3 1/2" (horizontal)by 2" (vertical) pattern with 3/8 inch mounting hole diameter, while the large bearing is 3 1/2" by 2 3/8" respectively with 1/2 inch hole size. Some of the mid 70's Torinos used a slightly different plate with a spacing of 3 9/16" by 2" respectively with 3/8" hole size.
Old 07-03-2009, 02:09 PM
  #33
cam
cam's Avatar
Interesting I didnt know that.... Maybe its a Canadian thing but I have never seen a 9" with anything other than taper bearings??? Unless by some fluke they were semi-floaters using c-clips? That too i have never seen in a 9" but I'm not saying they aren't out there maybe thats the reason?
I guess what I really should say... again... is taper bearings are superior on all accounts IMO unless I'm missing something here? I only run taper bearings its all i recommend. Havent had one issue yet
Those sealed ball bearing bearings are junk and theres vast differences in quality control amongst the different vendors.
I should also note I only run Timken brand they are the best too IMO.
Old 07-03-2009, 02:21 PM
  #34
roy
roy's Avatar
Cam,
I agree with you that the Tapered roller bearing is superior over the bal bearing setup.
I have my issues with my Moser nine inch and sealed ball bearings and road courses. The two don't mix well . Bearings wear quite fast from the side loading. If it was the large bearing ends it wouldbe easy to convert over , but alas it is the small bearing ends.
Old 07-03-2009, 02:25 PM
  #35
cam
cam's Avatar
I'd weld you up some new ends on there but.... me thinks that shipping here and back would cost more than a new diff
Old 07-07-2009, 05:33 PM
  #36
StreetStalkerZ's Avatar
Where exactly are you putting the RTV silicon at,around the race of the bearing?
I have the same problem and moser was no help at all on getting me a part number for the inner seal or bearing,thanks alot! Now that i have some part numbers maybe i can get this thing sealed up and stop leaking all over my ProStars.
Old 07-08-2009, 02:16 AM
  #37
Jimmard's Avatar
Mine have stayed leak free since I changed them to the napa parts a few days ago though I haven't driven it much. Keeping my fingers crossed, will post again in a few days.
Old 07-08-2009, 02:24 AM
  #38
Jimmard's Avatar
Does anyone know the pinion bearing and pinion seal part numbers as well?
Old 07-08-2009, 09:06 AM
  #39
BlackDuk98's Avatar
For the pinion, they are sold as bearings and races seperately. These numbers are Timkin:
Bearings: HM89443 & M88048
Races: HM89410 & M88010
Oil seal is a Ratech # RAT-6110
If you need any more #'s I saved every one since I replaced every damn part on mine.
Old 07-27-2009, 04:35 PM
  #40
silverbandit0996's Avatar
do all these part numbers work on 35 spline axles too?
Quick Reply: My Moser 9" is leaking at the axle.
