sheered 4 of 5 wheel studs..moser 12 bolt
we were talking about cutting off the ring. I did some redneck ingenuity and got the ring off without taking the bearing off. I ground a flat spot on two sides, drilled 3 1/4" holes on each one then beat a chisel all the way through on each side until it split! Worked good. I was kinda hesitant about using my blue wrench to cut off the ring. Now i can put in the new studs in and dont have to get the bearing pressed off.
