auburn posi unit info
Old 02-12-2009, 02:54 PM
murzyn123's Avatar
Default auburn posi unit info
i came across a new auburn posi unit for a 10 bolt 7.5" for $250 locally is there only one kind of auburn posi for a 7.5" 10 bolt or is there more than one, should i look at something before buying to check the fitment
i got a 2001 WS6 with one wheel peel
Old 02-12-2009, 05:14 PM
alamantia's Avatar
you will need the one for 28 splines
Old 02-12-2009, 05:46 PM
murzyn123's Avatar
cool should i double check that i got the 28 or all of our cars came with a 28
thanks
Old 02-12-2009, 07:01 PM
Justins00ss's Avatar
I believe they all came 28 spline. I just bought a Auburn Pro for my car, good piece
Old 02-12-2009, 11:34 PM
9000th01ss's Avatar
They're 28spline from early 90's and up.
They also come in 2 and 3 series. 3 series is for 3.23 and numerically higher gears and 2 series is for 3.08 and numerically lower gears.
You cannot use a 3 series with 3.08 down. You can use a 2 series with a ring gear spacer for 3.23 and up.
Old 02-14-2009, 08:31 AM
murzyn123's Avatar
thanks for the info
