9inch axle ?
Old Feb 14, 2009 | 09:56 AM
z28rob18's Avatar
Default 9inch axle ?
hey guy im tryin to put new studs on the 9" i just bought the rear is apart but we dont know how to get the parkin brake assembly off the axles? does a shop need to do this or? any help would be great
Old Feb 14, 2009 | 10:01 AM
Cliff's Avatar
Pull the cable out from the liner to give you more slack, then it should come off without a problem.
Old Feb 14, 2009 | 10:03 AM
z28rob18's Avatar
its lik one solid metal piece. there's no cable. we took the brake pads off but the big thngs in the way
Old Feb 14, 2009 | 08:29 PM
CW00BlackTA's Avatar
There is a hole in the backing plate (provided they are stock). You rotate each one to that location and remove and replace.
