Midwest Chassis Fab 9"
Old Feb 15, 2009 | 05:31 PM
madclown's Avatar
Default Midwest Chassis Fab 9"
Lets hear some opinions from those of you that have them and have been running them awhile. State what you ordered and if you were to do it again what, if anything, would you have changed about your order. Thanks..
Old Feb 15, 2009 | 07:11 PM
SS1875's Avatar
Best decision I ever made, wish it would have been out before I wasted money on the Moser 12 bolt I had prior to it.
My order consisted of the Fab9" housing, back bracing,transverse shock mounts, aluminum center, 31 spline axles(TCS/ABS delete), Detroit truetrac, MWC tunnel mounted TA, crossmember with DSS, adjustable LCA's, PHB, Strange 3" Chromeoly DS. Fully assembled and powder coated black.
The extra's are great, clips for the brake lines, drain/fill plugs, relocation brackets, DSS.
I wish I had gone with bigger wheel studs instead of the stock size
This thing went in very easily with some slight modification to my QA1's to make them fit the transverse mounts, it's quiet, stout yet light, and should take some major abuse....haven't had the pleasure of any track time with it but I have no doubts it will perform flawlessly.
Old Feb 15, 2009 | 09:40 PM
madclown's Avatar
[QUOTE=SS1875;11060164]I wish I had gone with bigger wheel studs instead of the stock size QUOTE]
Why is that? and also what is the benifiet of the transverse shockmounts? Thanks...
Old Feb 17, 2009 | 10:04 AM
madclown's Avatar
Any other thoughts? I talked with Eric and he said he will be building mine today...... WooHoo.
