Wheel Studs
Old Mar 9, 2009 | 06:31 PM
WS.666's Avatar
Default Wheel Studs
I bought a used Moser 9" and it came with ARP studs already on it. The problem is that they are 1.5" longer than the stock ones. What should I do? Buy longer lug nuts (do they exist?)? Swap out the ARP studs for the stockers?
Old Mar 10, 2009 | 04:58 AM
EPP's Avatar
EPP
You can use open faced lug nuts so the studs protrude through them, basically like a standard nut. This is required in the faster classes at most drag strips. Bob
Old Mar 12, 2009 | 10:14 AM
Strahley's Avatar
+1 for open lug nuts. McGard makes some nice ones
Old Mar 12, 2009 | 11:28 PM
01ssreda4's Avatar
dont swap in factory ones if you plan on racing. local guy bent all ten of his this weekend at the track launching from 6K.
Old Mar 14, 2009 | 01:00 AM
za355tx's Avatar
I had some arp studs...I just ended up cutting about 3/4 of an inch on them. So I kinda ended up back to stock length. My zr1's I had needed the longer studs (11 inch rears). Then when I got my TT2's the studs were too long so I cut them down some.
