bearings for a moser 12 bolt
i want to put new bearings in my moser 12 bolt and was wondering if anyone knew where i can get the right ones, and what their part numbers are?
i have these at home,,, i used Timkin's, found at auto zone for about 15 bux a piece
i want to say that the carrier bearings are "Timkin set 36" (comes with botht he bearing and the outer race
and the outer wheel bearings are "514003"
i will check my boxes (i kept em) when i get home in about an hour...im sure someone else would have gotten you your anser by then.
EDIT: 514003 (any brand i've found) and set 36 (Timkin 60312, and 60349, they come together in one box) is correct for the M12
Wayne
Wayne
Wayne
Wayne
Nope,,i got mine from Autozone,,Rileys, Advance, etc has em too,,,I got these numbers from Midwest Chassis when doing my project. Your basicly looking for bearings for a Ford 8.8 when your re-doin a Moser 12. The numbers I gave up top are the correct ones (for a 12). You can also find them from
Motor City (same part numbers)
PTC (same #'s)
Master Pro (same again)
and probably 15 other brands
Ask me how i know that,,,
((triple check your brake backing plate B4 pressin that bearing!
Wayne
PTC (same #'s)
![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
![Nod](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_nod.gif)
Wayne
