My rearend is leaking........
Old Mar 24, 2009 | 08:04 AM
sway99bird's Avatar
Default My rearend is leaking........
I have a 99 Trans am (A4) with the stock 10 bolt out back, moser axles everything replaced 4'11's, posi. Here recently I have had to remove the back cover on it twice. And after i'm done I put everything back together replace the gasket if needed, and after I drive the car and the axle gets warmed up the bolts come lose and it starts to leak. The second time around I put washers and lock tight and it still does it, so what do you think ?
Sway
Old Mar 24, 2009 | 08:19 AM
omcar's Avatar
get an LPW cover and torque bolts to specs.
Old Mar 24, 2009 | 10:22 AM
Bad30th's Avatar
You can use some RTV around the gasket to seal it up as well. Make a nice seal on both sides of the gasket and circles around all the bolt holes on both sides.
(and agree with the above, torque the bolts to spec, and a TA cover is a cheap investment)...
Rob (Bad30th)
Old Mar 24, 2009 | 11:25 AM
CodeRed2000SS's Avatar
yep, that will fix your problems
Old Mar 24, 2009 | 01:18 PM
sway99bird's Avatar
Thanks guys I will look into that
Sway
Old Mar 25, 2009 | 07:54 PM
wht01ws6ta's Avatar
I've never replaced one without using RTV and have never had a leak.
