QP 9" Rant
http://www.yukongear.com/ProductDeta...px?ProdID=5169
I was assured that it was good for 500+ wheel
Although it isn't through bolt design, we'll see.
http://www.quickperformance.com/Prod...20sections.htm
FWIW, it's a good idea to use a feeler gauge under the races to make sure they fully seat.
Mike
1 Missing hardware.
2 Torques arm bracket had to be cut to get the Spohn torque arm on.
3 I had to grind down both ends of my panhard bar because the space was too small.
4 I had to put the e-brake brackets on with an air hammer.
5 I felt grinding down the allen head bolts was sloppy for the caliper mounting plates, t-bolts is the proper way to go but I guess their to cheap.
6 The prep to paint it was i real pain. There was still mig wire on the inside and I had to grind a **** load of spatter. A bit of anti-spatter spray would have saved me 2 hours of paint prep. The torque arm bracket was the real pain in the ***. Also the bolts for the torque arm bracket that bolts it to the rear end have no shoulder, so you have threads in contact with a heim joint and it likes to bind on you.
They may be five minute jobs but I was using a friends business lift and having to wait two days for bolts to get in and other small **** I had to go home and get a tool for was a real pita.
If is definitely not bolt in. If I were to do it againI would buy a strange all done and pay the extra few bucks.
