Bulletproof 10 bolt?
Prior to getting these new gears, I busted 4 sets of 4:10 gears - these updated gears (3:73's for my Turbo) have lasted over 20,000 miles of hard driving - ZERO Issues!
A strong 10 bolt can be made, for about 1/8th the cost of an F-body specific 12 bolt, or 9 inch - I'm quite happy with mine!
But this isnt always the answer to give.. Because there are some of us out there, that want a 1- bolt, because we road race our cars or perhaps for other valid reasons...
I WISH there was a bulletproof 10 bolt...
lightweight, and no issues the 9" or 12 bolts give in road racing... wheelhop on decel, bad handling due to unsprung weight, etc...
eats less Hp than 12 bolt ot 9"
if there was a bulletproof 10 bolt, id be the first one to put my Money on it!!!
Unfortunately, The only thing that ive seen even come close these days is the MWC Fab9... Which I plan on investing in sometime later this year, possibly..
98, T/A, M6 ~320Hp N/a ~450Hp N2O
Last Nov I destroyed my Auburn Posi unit that was in the axle, so the items below are what I ended up putting into rebuilding it, stronger.
Welded axle tubes $0 (if you have a mig)
Mac Girdle $? (was on there when I bought the car)
Detroit TrueTrac differential $375 (Summitracing)
Axle bearings and seals $60 (Advance Auto)
Differential install kit (carrier bearings, shims, etc) ~$100 (Summitracing)
AMSOil 75-140w synthetic $60
I put my gears pretty close with little backlash so it whines, just a little when accelerating, otherwise its very quiet.
I've launched fairly hard on it with street tires and have been around multiple corners sideways without issue. Bout the only thing that I think will be next is when (yes, not "if" but "when" cause I feel pretty confident it will happen) the axles break when I have my stickys in the groove. I may have to lower my launch RPM to prevent wheel hop.
And when the axles break, its only a couple hundered for some Moser axles for it. Easy fix.
I too was not willing to drop $2k into a 12 bolt quite yet. As long as I keep it under $1k, I feel I am still doing good for a dd/street/strip car.
Not counting the gears (3:73's) because they were in there when I bought it, I am anticipating the axles to go next depending on how hard I launch.
