Bulletproof 10 bolt?
Old May 17, 2009 | 07:56 PM
Bird_Of_Prey's Avatar
Default Bulletproof 10 bolt?
I'd rather work with my stock 10 bolt, what would be the best stuff to use? Moser axles? Diff cover?
Old May 17, 2009 | 07:58 PM
BIG BAD BLACKSS's Avatar
No such thing as a bulletproof 10 bolt, not even close. Save the $ and get an aftermarket rear, you will save tons of headaches and $ wasted on new parts that will just break again.
Old May 17, 2009 | 08:00 PM
Elliott's94Z's Avatar
Grab a jar and throw $$$ into it every so often for when yours does go pop. No point trying to beef up the poop 10 bolt.
Old May 17, 2009 | 08:10 PM
01FbTaWs6's Avatar
i have never one said this, but search for this one. You will find there is no way to bullet proof a 10 bolt, and tossing money at it is pointless...
Old May 17, 2009 | 08:15 PM
Mine sounds like a train right now, so I need to at least fix it. I figured why not throw some good stuff in it.
Old May 17, 2009 | 08:18 PM
qwickLT1WS6's Avatar
If it sounds like a train and you dont have cash to get a legit rearend, just get another 10 bolt, they're cheap
Old May 17, 2009 | 08:26 PM
+1 Look for another one. My buddy has one for sale for $250 w/ low miles..there are lots out there to buy up on
Old May 17, 2009 | 08:34 PM
LCplmarine98's Avatar
I agree just have to save the cash, im in the same situation.
Old May 17, 2009 | 08:54 PM
trix-storm's Avatar
you can get one for dirt cheap like 100 bux or less honestly. just keep an eye open, and honestly, i wouldn't give a **** what the 10 bolt sounded like, if its working, let it be until it works no more and throw another 10 bolt in it and take the broken one to the junk yard. look for a used 12bolt or 9in, i got mine for 1100 with a fucked up torque arm adapter bracket, nothing a little bit of work didn't fix.
Old May 17, 2009 | 09:13 PM
It's not the money. I'd rather have a factory piece in the car. I'm not trying to run 8's, just make my weekend car a little more fun to drive. I don't think there is a bolt in 8.8, 9 inch, 12 bolt, S60, or other that is as quiet as a 10 bolt. If anyone has a lead on a good 3.42 4 channel 10 bolt, I'm very interested.
Old May 17, 2009 | 09:29 PM
Shockwave179's Avatar
Just buy another one, that's the best bet.
Old May 17, 2009 | 09:30 PM
My friend has the S60 on his and it's actually really quiet. Not much noise to be heard. If you are ok with paying shipping I'm sure my friend would sell you his. I would honestly look local first...if no luck he's got what you are looking for in great shape.
Old May 17, 2009 | 09:37 PM
SuperSlow02's Avatar
My 9in is pretty damn quiet considering what its been through...the only time my 10 bolt was quiet was when it was broke...and didnt move
Old May 17, 2009 | 09:41 PM
Slvr00Bird's Avatar
I've got a 3.42, 4 channel rear.. currently has a 3.73 in it and whines like a banshee (just as with the 3.42's) and is sitting out back behind the garage because after one rebuild (and the continuing whine), I decided to go with a Fab 9"..
Old May 18, 2009 | 05:40 AM
2001z's Avatar
I think everyone on here isnt looking at his ride lol. 9in and s60 isnt gonna work in his irs car . I would look into just getting it rebuilt or buying a stage 2 or 3 diff.
Old May 18, 2009 | 07:19 AM
TheLSgun's Avatar
Was wondering the same thing.
Are you talking about your vette? or do you own something else?
Old May 18, 2009 | 07:44 AM
Yeah, I just picked up an 02 WS6.
Old May 18, 2009 | 05:20 PM
ahhwataday's Avatar
If you are pretty much stock, get a master install kit and either Richmond or motive gears. You dont need moser axles. The main caps will break before an axle. Get the TA or MAC cover. It supports the weakes part of the 10 bolt. The main caps that retain the bearings for the differential and axles. If you are looking for more than 450 and have an auto or less than 350 and a 6 speed, rebuild the 10 bolt you should be fine.
Old May 18, 2009 | 06:15 PM
Not sure how far you are from chicago, but I am on the northside and will be pulling my 7X,000 mile (forgot exactly where it was since I started tearing the car down last year) 6 speed, 4 channel, 99' rearend out very soon and could let it go for $200 picked up. I will need the brake backing plates and brakes off it though. You can just put your brakes on this rearend. This rearend didnt make a peep for the 2-3 years I drove it.
Only reason I am pulling it is I ordered my midwest chassis 9" this morning.
Old May 26, 2009 | 08:48 PM
squealingtires's Avatar
Default Try this out for size...
http://web.camaross.com/forums/showthread.php?t=486663
