gear swap soon
Old Jun 1, 2009 | 06:13 AM
jmofield's Avatar
Default gear swap soon
Cars a 98 formula 2 series carrier stock 10 bolt with 2:73's. Already had 4.10's for the car from my previous camaro. not to worried about it being non posi because this car will never see the track or anymore than simple boltons. Anyways I have searched and found my question but no clear answer so here is my attempt at it. Does the car absolutley have to be tuned after the gear swap or what Ive seen mixed responses I know I will see more gains from it but I do intend to add a few more boltons as the money comes and would rather wait till im done then get it dyno tuned if possible? Also what else is going to be needed to do the swap? Do you have to have an install kit or just gasket and some rearend grease?
Old Jun 1, 2009 | 08:33 AM
sroach20's Avatar
your speedometer will be off till it gets tuned. since you will have everything apart you are better off installing new bearings. you may need shims.
