broke 12 bolt moser
Old Nov 7, 2003 | 11:18 PM
2001TA's Avatar
Default broke 12 bolt moser
Well I broke the ear on the bottom of the housing. The forward most bottom bolt hole where the torque arm bolts to the housing. Any body did ths before? Any how, I just e-mailed moser, so I will be waiting to see what they have to say. So far the best Idea I had for fixing the housing ear (short of buying a new rear) would be to stick a sleave through what is left of the bolt hole, weld it up, and re-tap. This would leave me using a smaller bolt though and the sleave would have to be welded very precise (90 degrees) to the ear. I'll post some pics later. Any ideas would be appriciated.
Old Nov 8, 2003 | 02:22 AM
2001TA's Avatar
Ohh, almost forgot to list the idea I had about the simplist fix of them all. just drill a new hole and tap it!
Old Nov 9, 2003 | 09:38 PM
2001TA's Avatar
ttt please
Old Nov 9, 2003 | 10:50 PM
Slowhawk's Avatar
LS1Tech Sponsor
I would say your idea sounds good.Thats what I would do.
Old Nov 10, 2003 | 03:35 PM
Noyzee's Avatar
8 second mod
Good luck with Moser, They wont do much for you.
But It sounds like your idea would do the trick, Just be carful, and make sure the other bolts are tight, Ive seen them back out on the moser's, mine did even with lock tight!!
Old Nov 10, 2003 | 04:01 PM
9T9BlueTA's Avatar
What torque arm did you have?
Old Nov 10, 2003 | 04:27 PM
Noyzee's Avatar
8 second mod
BMR Adj one, Not an extream duty, just the reg BMR.
I believe it also had somthing to do with the powder coating, so if you have one, i would grind the coating off where the bolts go threw.
My buddy B-Man had the same prob, but we didnt catch it, he snapped the tq arm, broke his drive shaft, and ruind his night.
Old Nov 11, 2003 | 07:34 AM
9T9BlueTA's Avatar
I do have a BMR one. I was going to check everything over in the spring anyway when I take the car back out. 2001TA or anyboy else do you haver pics of what happened?
Old Nov 12, 2003 | 08:29 PM
2001TA's Avatar
Haven't town it down yet I will post some pics though!
Old Nov 12, 2003 | 10:20 PM
Slowhawk's Avatar
LS1Tech Sponsor
I found with Moser that when the bolt's are tight,put a tack weld on them so they won't back out.Then if you ever have to remove it just grind the welds off.That is the only thing I found that really works with Moser's crappy design.
Old Nov 14, 2003 | 06:15 PM
2001TA's Avatar
tacking sounds like a good idea
