Moser "bolt in" 9" & Strange S case
Old 06-06-2009, 08:48 PM
Lone Warrior's Avatar
Default Moser "bolt in" 9" & Strange S case
Here are a few pics of the Moser 9" housing and what you have to do to make it clear the Moser torque arm mounting bracket.
Old 06-07-2009, 02:01 PM
ajrothm's Avatar
Cool, same setup I have....actually I have the Pro-nodular case and billet support etc...
I also have a 69' GP....factory 4 spd car. Wish it ran like yours though. LOL
Old 06-07-2009, 02:30 PM
Moderator
thechef's Avatar
i just trimmed mine (the case)with a grinder till it fit
Old 06-07-2009, 05:26 PM
98Camarod's Avatar
Is this the only case that requires trimming? What is this case rated to as far as power goes?
Old 06-07-2009, 09:21 PM
We can help you with your 69 GP , just drop about 1000lbs and get a fist full of parts for your Pontiac motor and you can be on your way
Old 06-07-2009, 09:29 PM
thechef - yea that is all we did too took a grinder to the case, didn't take too long to do
98Camarod - Strange claims they are 10% stronger than the factory "N" cases. They said their S case can handle upward of 800hp
Old 06-08-2009, 02:32 PM
CaliboyTA's Avatar
trim it. had to take out a chunk of metal on the torque arm bracket
Old 06-08-2009, 06:19 PM
We used the BMR #XTA001 torque arm and only had the grind on the Strange case.0
Old 06-08-2009, 07:02 PM
Jawsgear's Avatar
Notch the Strange Case for clearance, we have to do it on just about every 9" we put into the F Body cars.
Jeff
Old 06-08-2009, 08:35 PM
Hi-Po's Avatar
No grinding needed here, BMR adustable TQ arm
Old 06-10-2009, 07:06 AM
2002_z28_m6's Avatar
I just had to do that exact same thing to mine. Same set up.
Quick Reply: Moser "bolt in" 9" & Strange S case
