axle bearing and axle seal part numbers
I believe I have a bent axle, based on the noise and runout on the dyno on my car. I purchased some takeoff axles in great shape and am looking for the GM part numbers for the axle bearings and the axle seals.
If there are better seals/bearings out there, I am open to running those as well.
I just want to take the rear end apart once to fix it right the first time (as right as you can fix a 10 bolt that is
Any information would be great, all of the searching I have done, the results were all related to 9" and moser 12 bolt units.
Thanks,
Ryan
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
Thanks,
Ryan
