U-Joint Removal
Old Jun 15, 2009 | 03:41 PM
98Camarod's Avatar
Default U-Joint Removal
The u joint on the stock driveshaft doesn't have the snap ring. Is there anything special that has to be done for removal?
Old Jun 15, 2009 | 03:46 PM
Bad Blue WS6's Avatar
melt the lil viynl pins till they goo out of there, and whack it with a hammer
Old Jun 15, 2009 | 03:48 PM
post number 7,,,,
https://ls1tech.com/forums/gears-axl...t-install.html
Old Jun 15, 2009 | 04:03 PM
_JB_'s Avatar
You will need to melt the plastic mold, its a pain in the ***.
Old Jun 15, 2009 | 04:34 PM
98Camarod's Avatar
Originally Posted by Bad Blue WS6
Thanks, figured it was something different. I'll have to pick up a propane torch though.
Old Jun 15, 2009 | 09:21 PM
SS SLP2's Avatar
try the below advice, be carefull
good luck , Johnny
Originally Posted by romoranger
wear a face mask when you are using the torch. When I was doing mine the plastic inside pretty much exploded. It scared the crap out of me but somehow I was alright.
yep do not stand over the cap=some times the heat will cause the grease inside the cap to explod, have seen the cap go completely thew a tin wall/roof
Johnny
Old Jun 16, 2009 | 04:52 PM
01ssreda4's Avatar
^^^^ thats true.
