U joint install?
1.place driveshaft on block of wood so that the end your replacing is hanging over a little bit.
2.fire up the propane torch (use the gloves because it will get hot) and heat up the end cap (thats in the driveshaft yoke). Make sure you spread the heat around the cap and not in one spot. You'll notice that melting plastic will start running out of the holes.
3. Once the plastic seems done running out hit down on the end cap of the lose caps (the one that go on the rear end yoke) and that will drive out the cap in the drive shaft. Use your pliers and pull it out when you can
4.repeat steps 1-3 on the other cap.
5.let driveshaft cool down before touching it. Now take both end caps (the smaller ones) off the new u-joint and place the new u-joint in the yoke on the driveshaft.
6.place one of the new caps on the outside of yoke. Use your C-clamp to press it in the hole until it is flush with yoke. Making sure that u-joint itself is in the cap as you press it in there.
7.now loosen up your C-clamp and put your 3/4 socket (or smaller if it doesn't fit inside the yoke) and press into the cap pushing the cap further into the yoke. Stop once you can put the snap ring on the inside of the cap. And install the snap ring.
8.now do the other side the same.
9.you should be done at this point but check to make sure that u-joint moves freely. If not you need to beat the one of the caps back out until the u-joint moves freely. You'll hitting the caps that are not in the yoke (bigger ones) back and forth, until there is no binding on the u-joint. If you have to beat it out make sure to use a hard rubber mallet or a piece of wood between the caps.
Also be careful not lose any of the needle bearing in the caps. They shouldn't fall out but sometimes will, if they do just place them back inside of the cup. Remember this is how I do it and i'm not liable for anything you mess up. Good luck and hope this helps.
Johnny
When it's nice and hot the molten plastic will come shooting out of there, so watch out. Also watch out for the bearing cap, it could go flying as well.
