Moser 9"
Old Jun 29, 2009 | 03:00 PM
YSILT1's Avatar
Default Moser 9"
I just installed my Moser 9". Wanted to know if anyone has had a problem with the car sitting about 3/4 to 1 inch higher with the rear end swap.
I am wondering if the spring mounts are higher and causing the change.
I have checked my control arms, panhard rod, torque arm and shocks for binding. They have all been torqued with the suspension preloaded as to factory specs.
I am running Eibach Pro rear springs.
Old Jun 29, 2009 | 03:10 PM
01CamaroZ28's Avatar
i havent really noticed a difference when i had my 9" installed. im on stock springs too.
Old Jun 29, 2009 | 04:31 PM
Duffster's Avatar
drive it around for a few days and see if it settles back down.
Old Jun 29, 2009 | 05:59 PM
YSILT1's Avatar
I have driven it for about 2 days, but it has only been about 60 miles though. I will drive it more tomorrow.
Let you guys know.
Old Jun 29, 2009 | 10:43 PM
RamAir02TA77's Avatar
My car sat higher by about an inch or so I took out my upper isolater's and it dropped it back down to where I had it. I might do the heater hose mod to the springs.
Old Jun 30, 2009 | 08:26 AM
YSILT1's Avatar
Was the car any louder without the isolators. I was thinking of doing the same thing. Since the car has about 100 miles on it and has not come down.
Old Jun 30, 2009 | 09:23 AM
2002_z28_m6's Avatar
I was told if you cut one coil out and put the isolators back in it will sit level. I did the heaterhose mod and its a shade lower in the rear with my 9"
Old Jun 30, 2009 | 05:25 PM
NBMZ/28's Avatar
When I installed mine I did the heater hose mod and noticed the car stayed about the same height so maybe the spring perch does sit a little higher. I am on stock springs as well and am thinking about cutting a coil. I'm also on 26" DRs so maybe I won't.
Old Jun 30, 2009 | 06:13 PM
YSILT1's Avatar
After settling as much as i think it is going to go its about 5/8 inch higher than before. I might just leave it not sure. I guess I just loved the way it looked before.
I will try removing the isolator this weekend and let you guys know. I will aslo shoot some pics.
Old Jun 30, 2009 | 09:38 PM
real82it's Avatar
Mine did the same thing - I thought I was imagining things - well, now I know - I think I will cut a coil out and get it back down where it should be.
Old Jun 30, 2009 | 09:41 PM
Mikey 97Z M6's Avatar
Check to see if the rubber isolater is perfectly centered in the top mount.
Mike
Old Jun 30, 2009 | 10:04 PM
jetlag's Avatar
Yes, it was obvious to me that the car raised up a little bit.
Old Jun 30, 2009 | 10:15 PM
Intercooler2's Avatar
I could only wish the MWC 9" would do that. I need about and inch in the rear
Old Jul 1, 2009 | 01:25 AM
jetlag's Avatar
That's what she said.
Old Jul 1, 2009 | 06:01 AM
NBMZ/28's Avatar
^^^Nice!
Old Jul 3, 2009 | 08:14 PM
Carter01's Avatar
If you went from a 10 bolt to a Moser 9 just look at the difference of the diameter of the axle tubes, the 9 has much larger axle tubes which sits the rear of the car up higher. Just do the hose mod and your good. GL
Old Jul 3, 2009 | 11:04 PM
blue98Z's Avatar
Yeah it is going to sit a little higher with the 9".
Old Jul 4, 2009 | 11:08 PM
DAVESS02's Avatar
Same here but with the roads in Illinois, I just opted to leave it for the extra road clearance.
