View Poll Results: Best all around Gear Manufacturer
Moser
7.69%
Motive
92.31%
Strange Pro street
0
0%
Voters: 13. You may not vote on this poll
Gear brand poll!!!
Old Jul 27, 2009 | 12:12 AM
IKnowtheFuture's Avatar
Arrow Gear brand poll!!!
whats the best as far as power handling, quietness, and reliability?
Old Jul 27, 2009 | 12:37 AM
SyckWS6's Avatar
Richmond had a reputation for quality and durability, however they aren't known to be quiet by anymeans. Motive are moderately priced and are relatively quiet (or atleast the ones i owned in the past were). SLP ring and pinion sets have kept me very happy as far as durability and sound is concerned. They are a bit more expensive than the other two i have mentioned, but for now, they will be the brand i stick with.
Old Jul 27, 2009 | 06:14 AM
7.0 camaro's Avatar
i think gm makes the best gear. ive got pics of a 4.10 richmond gear sitting next to a 4.10 gm gear and the gm gear is bigger with more meat on it. and they are 3 cut gears while most aft. are 2 cut gears. that helps them be quiet.
Old Jul 27, 2009 | 08:10 AM
RARON455's Avatar
Yup, definately should have put OE gearsets in the poll, when I buy I would rather have a nice set of used factory gears than aftermarket ones.
Old Jul 27, 2009 | 08:22 PM
7.0 camaro's Avatar
the older s-10's that had a 2.5 and 5 speed had 4.10's stock. the stock gear is on the left. the busted up richmond is on the right.
Attached Thumbnails Gear brand poll!!!-l_4466c1e531394c29899f57879b3f9c7a.jpg   Gear brand poll!!!-l_16adbb8296eb413bbe93fd7504f693a8.jpg
Old Jul 27, 2009 | 09:03 PM
2000Z28M6's Avatar
I have a set of GM 3.73s on mine and no complaints.
They tend to drone a little around 60-70mph, depending what rpm I'm in..but honestly I think even the 3.42s were about the same. I think the rears tend to whine a little stock or not.
I had a little mishap when I first had them installed (******* curb) and the pinion bearing got trashed, it whined loud! Had the bearing replaced and it's been great!
They've been in for over 2 years and holding up nicely.
Old Jul 27, 2009 | 09:10 PM
jetlag's Avatar
Does Moser have their own gears or do they use another company?
Old Jul 27, 2009 | 11:46 PM
SHovV's Avatar
looks like OEM FTW.
Old Jul 28, 2009 | 12:58 AM
jimbo98z's Avatar
Moser makes their own gears. And mine sucked from them. Put a set of Yukons in the 12-bolt and they seem to be pretty solid. A little noisy, but that's due to how it's set up, not the gears themselves.
Old Jul 28, 2009 | 10:22 AM
kmgsix08's Avatar
i vote GM. i waited to find a set of GM 4.10's before doing the rear end rebuild
Old Jul 28, 2009 | 10:33 AM
sroach20's Avatar
aam are good ones.
Old Jul 29, 2009 | 10:12 AM
kmgsix08's Avatar
Originally Posted by sroach20
aam are good ones.
i was just informed that AAM makes the gears for GM
Old Jul 29, 2009 | 10:39 AM
7.0 camaro's Avatar
nice to know. i wonder whats the price difference on a new gear. i usually get them from pull a part.
Old Jul 30, 2009 | 12:06 PM
01ssreda4's Avatar
i just installed summit 4.10s in an auto car and . Maybe summit (noisy *******) are made by richmond?
Old Jul 30, 2009 | 01:27 PM
7.0 camaro's Avatar
very possible. not sure exactly though
Old Jul 30, 2009 | 10:43 PM
C_B64's Avatar
I like Motive, but the last gear I got was a Yukon Gear and its pretty quite and seems to be fine......
Old Jul 30, 2009 | 10:52 PM
98silvertacrbn's Avatar
I had the same set of gears from summit and they were noisy as **** also!!
But i have installed several sets of motive and oem ford gears and they have all been quoit
