8.8 Build
Old Jan 4, 2010 | 05:38 PM
  #161
98silvertacrbn's Avatar
Originally Posted by munsterz28
i am doing this exact swap into my 96 z28. did you have to call moser to get those axles custom made? thanks im subscribed
Yeah i called moser and had them make 94 to 98 axles with no abs rings drilled in chevy 5x4-3/4" i think they were 290 shipped and about two weeks total to get them. Here's the number 1-260-726-6689
Old Jan 4, 2010 | 06:10 PM
  #162
munsterz28's Avatar
thanks so much!
Old Jan 4, 2010 | 09:25 PM
  #163
Blownz28man's Avatar
So what are the width differences in different years of the 8.8's? Also axle lenths? I miss something? 4" shorter than a 93-02? so same size as a 82-92?
Old Jan 4, 2010 | 09:59 PM
  #164
79 to 93 mustang 8.8 are 58 1/2" wide while 94 to 98 mustang 8.8 are 61" and stock lenght for 93 to 2002 f body are 65" all these mesurements are to the outside to outside of the rotor hats
Old Jan 4, 2010 | 10:07 PM
  #165
chevymec's Avatar
Subscribed!!!
Old Jan 4, 2010 | 10:42 PM
  #166
So whats the deal with 98 and up? They say there 62.5" Hub to Hub. What is the diff?
Old Jan 5, 2010 | 08:39 AM
  #167
You mean 99 and up i think it comes down to axle choice
Old Jan 5, 2010 | 10:09 AM
  #168
So not as many aftermarket axles? Maybe different diffs? All info would be appriciated
Old Jan 5, 2010 | 10:20 AM
  #169
No each different style mustang used different length axles fox bodys 79-93 sn95 94-98 and 99 up was all different length you just have to chose what works for your application.
I used the 94-98 axles because when installed finished length was exactly 4" shorter then a stock 10 bolt
Old Jan 5, 2010 | 10:23 PM
  #170
So it sounds like 94-98 axles in a 79-93 housing will work for me than. Put me pretty close to factory width. Thanks
Old Jan 6, 2010 | 09:17 AM
  #171
Yes the 94-98 axle will work in a 79-93 housing you just need to change the backing plates
Old Jan 7, 2010 | 07:58 PM
  #172
ok thanks. Love this thread! I'll be making my own when the time comes. Looking at buying a scrap 82-92 rearend for the brackets and tubes and a 8.8 for the center section. You suppose a truck 8.8 would work? or atleast the center section? How about if it just costs a case of beer?
Old Jan 7, 2010 | 08:01 PM
  #173
whitelt1ta's Avatar
i was wondering for those that have just had the 8.8 tubes cut off and then had the fbody tubes welded on, what axles are they using?
Old Jan 7, 2010 | 08:09 PM
  #174
silversrtman's Avatar
subscribed
Old Jan 7, 2010 | 08:12 PM
  #175
Only bad thing about the truck and explorer 8.8 is the weight of them. The mustang 8.8 is the lightest
Old Jan 7, 2010 | 08:28 PM
  #176
I think this is going to be my new ladder bar setup this spring. I am going to build them from scratch going to run the lower bar parallel with the cars body then slope the upper bar down right before it makes body contact. Of course these will be made out of rod ends and cold drawn dom tubing so i will have more then one adjustment for my suspension. It should convert my setup to a regular ladder bar not a short ladder. Not that i have had any problems with current setup but if i am going to build lower control arms i might as well get the benefit of full ladder bars.
Excuse my bad Ms paint skills
Old Jan 7, 2010 | 08:51 PM
  #177
Yea.. weight wouldn't be anygood then...why not go with a 9" than hu? Wonder how much weight? 5-10lbs?? So are you gonna pre set your pinion angle or put an adjustment in there? Looks good!
Old Jan 7, 2010 | 08:53 PM
  #178
I think they are just getting custom built axles that are mustang length but with chevy ends.
Old Jan 7, 2010 | 08:58 PM
  #179
mike13's Avatar
Chevy length with mustang ends.
Old Jan 7, 2010 | 09:44 PM
  #180
Randy WS6's Avatar
I had my axles cut with GM hubs bolt pattern & bearings for my f-body and had them splined to 31 for the 8.8
