4ch rear into 3ch car question
Has anyone figured out what to do when installing a 4channel rear into a car that came with a 3channel rear.
Problem I have is I just bought a used(moser) 12 bolt with a eaton posi that was in a 4channel car but my car is setup for a 3channel.
Is there any way to get the ABS to work without changing out the rear carrier so install a reluctor ring and drill a hole up top for the sensor.
taking it apart and putting the reluctor ring on and drilling a hole in the top for the sensor would be the only way to keep your abs. i had the same problem when i picked up a used rear, 4ch rear 3ch car. it wasnt that bad to do. talk to scott at DLS, he helped me out greatly by putting a reluctor ring on my spool for alot cheaper then what the ring from moser was. thats if you can get them to sell it to you, they tried telling me a needed a whole new rear.
