What is a rear end?
The entire rear axle assembly between the two rear tires. ALL F-body rear ends totally suck as a result of small diameter gears that are prone to breaking when the motor is hopped up. They even break on stock motors more than they should.
GM did this to reduce cost and stretch MPG's.
When I first started learning, I didn't know the difference between a rearend and a differential.
