Will it break?
Old Aug 19, 2009 | 02:19 AM
XtremeDime's Avatar
Default Will it break?
Ill be pushing about 450ish turboed. Ill have a stock 10 bolt and clutch, dropping it at about 2500ish RPM(turbo reaches full spool about 3k). Will I destroy my rear?
Old Aug 19, 2009 | 02:21 AM
13lu91rS's Avatar
dont dump... slip it.
i have an ls7 clutch and 3.73's.
2500 dump= 2.2-2.1 60'
4k slip= 1.920 and there is room for improvement.
Old Aug 19, 2009 | 02:23 AM
XtremeDime's Avatar
just rev it up to X RPM and slip it out? I dont have much experience(by much i mean zero) racing manuals. Also when I shift from 1-2 and 2-3 do i rev it up in between gears and slip it in also. Or just let off, shift, back on it?
Old Aug 19, 2009 | 05:22 AM
Intercooler2's Avatar
Yup for sure!
Old Aug 19, 2009 | 06:23 AM
13lu91rS's Avatar
When you hit the 2nd stage light rev up to said rpm and hold it there. Soon as you see the 3rd yellow start coming out of the clutch pretty quickly. You should be fully engaged around the 60' mark, maybe a little before even. You can keep your foot on the floor when you shift if you like or you can pick it up. But just so you know I picked up a .10th and I think 2 mph by keeping the gas on the floor. You don't have to slip at all going into second or third tho. Just get that sucker into gear as quickly as your comfortable doing.
You want to stage in a high enough rpm so you don't bog coming out of the hole. It's just a process of trial and error. My lt liked 3k and this car likes 4. But good luck and keep us posted
Old Aug 19, 2009 | 06:49 AM
BlackScreaminMachine's Avatar
Internet Mechanic
Yes, IT WILL BREAK!
Old Aug 19, 2009 | 11:07 AM
01ssreda4's Avatar
The driver of a M6 determines when the 10 bolt will break.
Old Aug 19, 2009 | 11:50 AM
dschmittie1's Avatar
I cut 1.7 60's with my 10 bolt and my 600rwhp last year many times. And I removed the 10 bolt from the car in favor of my 9" in working order. The key is slipping the clutch. I was holding the rpms up around 2500-3000 and slipping the clutch. Basicly not letting it comepletely out until the car was moving good. Worked very well. car went 10.5@135mph like that.
Old Aug 19, 2009 | 12:12 PM
01ssreda4's Avatar
^^^thats awesome, I think the goal is to lighten the intial shock to the rear.
Old Aug 19, 2009 | 12:20 PM
exactly. I also lifted on shifts. Yes taking the initial shock out of the drive train and not trying to dead hook is what saved my 10 bolt.
Old Aug 24, 2009 | 09:08 AM
LS1Adam84's Avatar
I have an auto with a 3k stall and trans built for some serious business. My rear is a 10 bolt with roughly 66k miles on it, I have done so far quite a few launches with street tires and about 11 hard launches with et streets on. Just bought some m/t's dr's and well lets just say she is whining now and hates me.
There are people who can make the 10 bolt last. This is my second one, and I am dumping it in favor of a 12 bolt. I say have fun until she breaks in the mean time save up for a 9 in or 12 bolt which ever tickles your fancy. 10 bolts will break I have people saying ohhh they are great blah blah blah, fact of the matter is tehy will break the more you race it, and even more so on a manual trans car cause you are shocking it everytime you launch.
Old Aug 28, 2009 | 06:20 PM
NSSANE02's Avatar
+1 on slipping the clutch. But you're still not safe with any kind of real power. Even a power shift can kill it.
Old Aug 29, 2009 | 02:14 AM
Sofls1's Avatar
You may get it to live for a while based on the methods noted above, but that will only last for so long. In short; it's not a question of "if" rather "when" will it break.
