Silly Question about Rear Diffs . . .
The question is, when I turned the one of the rear wheels the other wheel did not turn, isn't it normal for the other tire to spin the opposite direction when the other tire is turned?
Just want to make sure the diff isn't fubared!
And to note it is the stock diff with aftermarket 3:73 gears
Find somewhere away from the Popo and do a quick burnout.
Look at rubber lines on the pavement.
2 lines (both wheels spinning) ...posi is fine
1 line (only one wheel spinning) ...posi has a problem
First thing to check if there's a problem is the diff fluid (amount & cleanliness).
Maybe even check that before the burnout test.
Have fun!
