moser torque arm bracket failure
Old Sep 17, 2009 | 10:00 AM
TJ's Avatar
TJ
Default moser torque arm bracket failure
i called moser to see if they had any failures and whatnot. i was told im abusing my car? thought thats what it was for?
high hp, heavy car, but mostly a very shitty weld.
good thing i broke my center section, or i would have had more trouble in the next few passes.
this bracket is damn near 20 pounds and made of 1" flatstock. the flat place between the plates for the torque arm mount has to be 3/8 or 1/2 thick.
you can see its shiny, no rust after a week of being off the car.
had to beat the torque arm off the car. you can see the bottom portion of the bracket is bent/warped. heated it up and layed it on the ground and swung a 15LB sledge at it numorous times and it never moved.
hard to believe the suspension has that much force on it.
driveshaft yoke also took a hit.
i havent had the driveshaft out in 30 passes. the splines are twisted so bad i had to beat it out of the tranny with a hammer.
it will not full seat into the transmission anymore.
need to sell the car and build something light.
Old Sep 17, 2009 | 10:58 AM
Intercooler2's Avatar
Holy heavy metal!
New boat anchor LOL
Old Sep 17, 2009 | 12:40 PM
SIC LSX's Avatar
yeah WTF. They say oh your ******* it! You have a part made for drag racing lol. Why im going midwest
Old Sep 17, 2009 | 06:40 PM
wforty94's Avatar
mine didn't have any welds on it if i remember correctly. it was all casted in one piece. maybe this is an older design?
Old Sep 17, 2009 | 07:00 PM
HUNTER02SS's Avatar
Damit ! That sucks. I hate to see this. What center section you running and what spline axles?
Old Sep 17, 2009 | 08:40 PM
SIC LSX's Avatar
Stock N and 31 spline
Old Sep 17, 2009 | 09:28 PM
TJ's Avatar
TJ
all stock center.
ive got a moser thru bolt and billet goodies in there now.
new chrome moly tranny yoke is on the way too.
the th350 input shaft will be the next weak link.
dont think anything else on the car will break now.
ive broken all the cheap stuff over the years.
Old Sep 17, 2009 | 09:29 PM
TJ's Avatar
TJ
i think the cast piece is only a couple years old.
i dont see how iron would be stronger than a piece of steel.
moser says for faster production.
anyone have a pic of the new bracket?
Old Sep 18, 2009 | 05:02 AM
EPP's Avatar
EPP
These pictures are from early part of 2006. Bob
Old Sep 18, 2009 | 07:27 PM
wforty94's Avatar
my torque arm bracket looks like the one bob posted, all one piece solid cast iron. my moser 9" is about 2 years old and the bracket is very very heavy and solid..
by the looks, it appears to be much more heavy duty than the piece you posted. even if it was weaker which i highly doubt, there are no welds to break
Old Sep 18, 2009 | 11:04 PM
TJ's Avatar
TJ
a weld shouldnt break, but we could argue about that one forever.
when i get rich, id really like to move away from this rearend and the current torque arm setup i have.
the tranny brace, torque arm are mild steel, and that bracket is way over weight.
i bet with a fab 9 and a chrome moly torque arm i could drop 30-35 pounds from my car.
Old Sep 19, 2009 | 10:48 AM
Chris05ssTruck's Avatar
Why u needed to do it BALLER!!!
Even the skreet car around the corner has one!!
By Brett Foote | 2026-06-04 05:00:17
