moser 12 bolt abs question
Old Sep 26, 2009 | 10:42 AM
willywirehand's Avatar
Default moser 12 bolt abs question
Will a 12 bolt moser rear that came out of a TCS car work with my ABS only car? Will I have to do away with the ABS or can I make it work?
Old Sep 26, 2009 | 10:52 AM
dockSS's Avatar
Talking
no problem its a direct fit. both the abs and tcs read from the same sensor so there the same plug. make sure to weld the SMALL 1/2-13 bolts to the T.A. or it will come loose and have very expensive repair
Old Sep 26, 2009 | 01:13 PM
my stock rear has one sensor in the middle, the tcs car has two sensors, one on each end at the wheels
Old Sep 26, 2009 | 04:18 PM
stevo92z28's Avatar
No, it is not going to work unless you drill a hole in that carrier and install a reluctor wheel on the pinion gear. So it's cheaper to find another 12 bolt for a 3ch car, or just ditch ABS and run it that way.
Old Sep 26, 2009 | 08:32 PM
HMFDZ28's Avatar
The reluctor for a 3 channel is on the Carrier... I started goin this route and you are better off finding a different rear or ditching the ABS. I chose to ditch the ABS.
