Speed Calibration
You are simply using the wrong tire height or gearing in the programmer. The percent error in the calculation (caused by using the wrong numbers) means that as your speed increases the difference between actual and displayed (by incorrectly calibrated speedo) will increase as well. There's nothing wrong with the sensor.
Find an online tire size calculator to verify your actual tire height.
Either way it's not physics, it's mathematics. I already told you that the discrepancy between actual and indicated speeds WILL CHANGE WITH CHANGE IN SPEED. If you can't take my word for it then do the math at different speeds for yourself. You will find that indeed the span is greater at higher the speeds, but that the span will always be the same PERCENTAGE (ie; 6% off). It is not constant, even though you may think it should be.
Check your 5 volt reference. It's almost certainly an isolated issue (non PCM) otherwise you'd be having problems with lots of other sensors as well. I would still expect the problem to be erratic instead of smooth if there was an issue with the reference.
Then if you don't know your gearing from the RPO codes then maybe you need to climb under the car and spin the wheels/driveshaft and compare.
