crush sleve
Old Oct 8, 2009 | 03:37 PM
frawsty's Avatar
Default crush sleve
ok guys i need to know the proper procedure and torque specs for crushing the cruch sleve
Old Oct 8, 2009 | 04:16 PM
omcar's Avatar
Default crush sleeve
just my 2 cents but i would get rid of the crush sleeve and get a solid pinion nut...less to worry about.
Old Oct 8, 2009 | 04:43 PM
frawsty's Avatar
well i sorta need the car back now i really cant wait for parts
Old Oct 8, 2009 | 06:17 PM
koolaid_kid's Avatar
Here is a link to the entire procedure: http://www.keliente.com/gears.htm
Procedure is there, but no values.
Here is a different link: http://www.geocities.com/MotorCity/Downs/4013/re.html
Value is in one of the pictures, but not as detailed in the information as Keliente's link.
Old Oct 8, 2009 | 07:32 PM
01ssreda4's Avatar
tighten, check, tighten, check, tighten, check. I stop at 25 inch/pounds.
Old Oct 8, 2009 | 07:49 PM
454SuperSport's Avatar
yep, just keep tightening the pinion alittle at the time until you get the right preload on the bearings. around 25 inch/pounds with new bearings, or 15 inch/pounds with used bearings.
Old Oct 8, 2009 | 07:54 PM
frawsty's Avatar
ok and can i do this with a standard torque wrench or do i need one with a dial and needle
Old Oct 8, 2009 | 08:04 PM
most of the small (0-90in/lbs. for example) are dial and needle types.
Old Oct 8, 2009 | 08:12 PM
frawsty's Avatar
except the one i have
Old Oct 8, 2009 | 08:14 PM
frawsty's Avatar
thank you guys im going to try to do this now
Old Oct 8, 2009 | 10:16 PM
01ssreda4's Avatar
get the one with the needle. A clicker type will not work
Old Oct 10, 2009 | 09:18 AM
frawsty's Avatar
i ended up using a deflecting bar type i could not find one with a dial to save my life
Old Oct 10, 2009 | 10:13 AM
01ssreda4's Avatar
Thats the kind I have also......I believe they are called beam style.
Old Oct 10, 2009 | 05:49 PM
frawsty's Avatar
o theguy i borrowed it from must not know the proper name doesnt matter problem wasnt solved so i think im just gonna stick a spool in it for now
