Moser 9" ABS problem..... EPP can you HELP?
ref: https://ls1tech.com/forums/suspensio...dif-gears.html
Every time I press the brake pedal I get the ABS module pulsating trying to work but it just doesn't. Is there anything I can do to check the 9" rear sensor to make sure it's reading the reluctor ring correctly?
