New rear with dif gears
Put a Moser 9" in her a while back and ever since then ABS light is on and every time I place my foot on the pedal I can feel the ABS module pulsating and trying to work. Is this due to changing the gear ratio?
I only went from 3.73 to a 3.75....... And I opted for the reluctor ring with the iron pumpkin.
Gear ratio wouldn't do that. Different sized tires front to back will. Perhaps the new reluctor ring has an incorrect number of teeth or the air gap to the sensor is incorrect. Find a good tech to diagnose it for you if you think it's the rear.
Vernon
Vernon
