Cam and a 10 Bolt. Are you doing it?
Also I have an Axle Brace kit from LPW, I was going to send it back because Im going to this 9 inch...if your interested PM me and Ill show u some pictures..its helps with tube flex and thats one of the common problems with the 10 bolt.
I put down 412rwhp and 381rwtq...
I have launched it a dozen times at the track between 4k-5500k launches. The stock 10 bolt was as silent as the day it came off the factory line....these were with 3.42's...I beat the ***** off my car. I have the stock gears sitting next to me and they look brand new with a excellent wear pattern.
Now, last week I just had 4.10's installed. Im sure that will be a different story.
my 3.42 10 bolt has gone 10.6's with 1.41-1.45 60 foots on a previous motor..bone stock rear. automatic trans.
My buddy has gone 1.38-1.39 60 foots and 10.0's on another stock 10 bolt but with 3.73 gear i believe. Automatic
If its an automatic it should hold fine... but deeper the gear ratio you go, the less material on the ring gear so it may fail. My 3.42 failed finally but it was a worm gear in the zexel unit that chipped...gear was fine.
manual trans and sticky tires with grippy clutch may frag the 10 bolt soon. My buddy went 1.38 60' with his th350 but swapped to a T56 and did many 1.5x 60's with quick slip of clutch off line. That was a 11.0 car with the stick, mid lower 10's on spray.
Now with this car, I just broke the 10 bolt on stock power with street radials. Powershifting and a few trips to the track did this one in.
