10 bolt gear pattern check
I have not used the pinion depth tool. Have you used it with success? I was giving the purchase some thought for 100 bucks it would save TIME.
I use a depth mic I borrow from work. Set it up per manufactor spec's and have never had a problem or a whine. And they always have a good pattern. $100 would save a lot of time. and then you can charge your buddies $150 to do their rears and pay yourself back in one rearend setup. I don't us a set up bearing, I use the bearing that is going to be run in the car. I polish the pinion so that it slides on and off with ease. Don't forget that you need about .010 preload on the carrier. And I use a dial indicator to check the back lash on this.
Make damn sure you have the correct preload on the pinion or the readings will be off. Same with the main cap torque.
You are going to have to try all different types of combinations till something looks right. The way gears work, the pattern can wake up with as little as .003" of shim once you hit the sweet spot. If you overshoot it, it will go to Hell.
10 bolts are the worst gears to set up flat out period. They are a PITA becuase of the assembly and disassembly required to find the right setup.
Put the .020" back in and increase the backlash to .012" and get the patterns. I am thinking that .020" may be close but now it needs some BL. Make sure to thin the compound out, the patterns are hard to really see in the pics you have posted.
Never had the problem. I would imagine that the crush sleeve has enough preload to keep it from spinning. It's just the same as the front bearing, just slips on. What keep it from spining? The yoke you say, well the face of the pinion gear also helps keep the rear from spining.
I am going to pick this project back up in the spring. Snow will be on us soon in Upstate new york and I need to get to other projects.
Thanks for the input it has been helpful.
My take away is that I need a Ford 9".
I set up a 68 carprice 8.2 ring and pinion and got it right without much difficulty.
This 10 bolt is a PITA as you said. I have an M6 to rebuild this spring so I will get the whole driveline then. I have good notes and advise from you guys. thanks
and the f-body struggle with the 10 bolt continues.
Whistlen6 found this....
http://ratech.stores.yahoo.net/noname4.html
Just curious to what you used.
this is the other depth gauge. I may just get it instead of the ratech one listed above that is only specific to one gear set.
http://www.streetperformance.com/mis...0719/66516.pdf
Looks easy to use. Just make sure you check the tool setup more than once. And when you check the pinion depth, make sure you have the proper preload on it. I usually do this without the crush sleeve-so you don't waste it, and then once it is set, take it apart and put the crush sleeve in. Then recheck everything. With new bearings and seals you should need about 25 inch pounds of force to rotate it.
9" is so easy to setup it will blow your mind. Pinion shim changes take only a minute or two and so do backlash adjustments. Plus you can set the gear caes up on the bench and set the gears. None of the PITA stuff like every other rear end around.
I want to get a 408-LQ4 in the mix next year that is going to eat up some cash and a 10 bolt. so I need to juggle the funds.
