93 m29 t56...3.73's or 4.10's
i know the m29 has closer gear ratios than the 94-97 t56. (the m29 has the same 1st-4th gearing as the c5 z06) so since it has lower gear ratios, should i go 3.73 or 4.10 rear end gear? the car is driven on the street but is a weekend strip car. not my daily driver. thanks
Whats the final gearing of 6th gear? If its somewhat close to the later T56s I would go 4.10s. I currently turn 2000 rpms at 65 with 4.10s and a 95 T56 plus it makes the car so much fun, lots better than stock gearing anyway.
