Differences Between LT1 & LS1 Rear Ends?
I believe tube length to be the same, I am almost 100% suree but I have never measured. The cross pin in an Auburn is a smaller diameter then the width of the thrust block in a torsen, hence the axles that go in the auburn I believe to be slightly longer, so if you use the torsen axles with auburn posi or visa versa there could be a clearance issue with the brakes.
GM parts manual shows same axle part numbers for 98 Auburn and 99-02 Torsen.
BUT,Auburn pin is .764" dia. and Torsen block is .936" thick,which means axles with a Torsen would be .086"(just under 3/32') out further.
