pix of Crush sleeve
is that picture from an FBody? Because my new crush sleeve is the same length on each side of the center bulge. It also answered my question I forgot to ask - do you install the bearings dry or should you use some type of pre lube?
If I remember correctly, the 10-bolt crush sleeve looks like you describe it, equal distance with a buldge in the center.
Always lube the bearings when installing them, soak them in gear oil.
http://cgi.ebay.com/ebaymotors/Ratec...Q5fAccessories
http://i275.photobucket.com/albums/j...d/IMG_4736.jpg
Or fabricate something that looks similar.
However, if I was setting up my own rear and wanted it exact, I'd prefer to have a torque wrench and holding tool, like the ones that were posted.
I'm thinking the whole thing reassembled and using the parking brake would hold it just fine. But what spec would I be looking to get turning the whole rear with axles? and would that be with or without wheels?
