whats the difference...
Old Dec 27, 2003 | 02:21 AM
RAMnGO's Avatar
Question whats the difference...
well i'm kinda new to rear ends and how they work for daily drivers. I'm looking at a ford 9" but i see alot of ppl have either a spool or detroit locker. What is the difference between a spool, mini spool and detroit locker? also which is best for daily driver that occasionally sees the track.. this is my only car too btw...
Old Jan 4, 2004 | 08:21 PM
SStingray's Avatar
Spools are the same as a solid axle hub to hub. They are not for the street. The locker is like a ratchet and will unlock when turning to allow the inside axle to turn at a slower speed. It will also make a clicking noise when the axles are not turning the same speed.
Old Jan 4, 2004 | 09:19 PM
Slowhawk's Avatar
LS1Tech Sponsor
The Detroit locker is pretty loud when turning.The spool locks both wheels so there is no slippage..You will probly be better off with an Auburn (clutch disk type)posi since it's mostly your daily driver.
