Moser 9" with Detriot Tru-Trac Making Noise?
bob i have tried emailing you as well, if you can contact me ASAP, the 23rd was the date i purchased it a year ago, and moser and eaton have been of no help, i call and email them with no response. if you can get back with me soon id appeciate this!
LS1Tech Sponsor
I pm'd you this morning. Thanks. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
![](https://ls1tech.com/forums/signaturepics/sigpic168855_1.gif)
Sorry for bring this one back to life, but Mine had been popping around slow speed right and left turns too for about a 8 mo. I decided to start tearing things apart this evening. I haven't removed the pumpkin yet to inspect the true-crap and found my drivers side axle jacked up and almost twisted right off.
![](http://i256.photobucket.com/albums/hh187/cdh6969/car%20stuff/driverssideaxle31spline.jpg)
OP what was the outcome from your scenario? I hope I don't have to buy another diff. Axle is a given, but another diff is expensive as hell.
it seems like i'm getting this all too common Tru-Trac clunk, and it's a MEAN clunk....but it's only on slow corners when i have very little throttle imput, give it more throttle the clunk goes away...coast, with it in gear clutch out, no clunk. reverse...no clunk, even with throttle. happens on both left and right hand corners, and it's getting worse after my last trip to the track. still drives straight under heavy acceleration, no pull left or right, and both wheels still burnout. Does this sound like the posi unit is going bad?
well after the track today, had some 6k dumps and now the rear "pops"
around right turns? drives fine straight, both wheels spin, no other abnormalitys besides the occasional right turn pop.. anyone else had a similar issue, or did i trash the carrier? it is only a H/C car... hopefully someone chimes in before i tear into this thing tomorrow! thanks
I will be interested to see what the problem is and what you end up with.
LS1Tech Sponsor
This problem does not happen with the Trac-Loc, only the Truetrac. The Truetrac use to be a very good differential until the company got bought out, sometime back around 2006. Since then quite a few people have been having this problem occur with them. Bob
__________________
I have only about 10 miles on my setup and when I perform a slow turn to the right I hear a poping noise and it sounds like its coming from the rear end mainly near the wheel.
This couldn't be a Trutrac failure this early
LS1Tech Sponsor
Check to make sure the floors sheetmetal is not rubbing the torque arm bracket. Bob
__________________
#32
i have detroit true trac also, 200 miles and counting up, no slicks yet but i hope that it will stay good. i dont really track the car though only street duty.
If in case the true trac goes bad, and i want to get wave trac do i need to change the axles also? they are 31 splines btw.
#33
#36
I picked my car up last Friday after installation of a new Moser rear end with tru trac and I have a popping sound when turning left and also a whine in the rear end. The popping sound occurs when turning left and when slowing to a stop. Also have a slight whine in the rear end. This does not seem normal for a very expensive new rear end. Comments please. Only fifty miles on the rear end.
#37
#38
GM F-Body Bolt-In Pk
Moser Perf Nodular Case
Truetrac Posi
#PS028 - Alum Daytona Support
Setup Kit - 28 sp Pinion
1350 Pinion Yoke-steel
Moser P/S Gear - 3.50-4.57
Channel ABS w/exc. Rings
This is list of what was installed and have the popping sound and whine.
Truetrac Posi
#40
I have a call into Moser regarding the clanking noise in my new Moser 9" rear end with true trac. Also sent e-mails to Moser with exerpts from other members regarding the noise in the new rear end. I purchased the Moser Rear end based on recommendation from some local shops. Are they a reputable company? I have just talked with Mike McCombs of Moser and he said that he is not aware of the issue of the clanking or bumping sound in the rear end and he said that there are probably one million of these units out there. He suggested that the members of LS1 tech were doing more posting than making calls to the manufacturer. Mike seemed to be a head's up guy. Putting car on lift later this afternoon to inspect.
