12 bolt transfer
The 94 z28 was set up for the 3 Channel and the 02 is a 4 Channel.
I had to send my axles out, I trusted Moser to Machine, press, and put on new reluctor. I also sent them my different backing plates so that the bearings go on after the plates (like a sandwich).
I plugged the top (left the sensor in) BUT you can just find a bold and RTV on there since the 3 channel is no longer going to be used.
Also spend the $$$ now and get a upgraded Driveshaft, just get the yoke size/model # so the U joint will be correct.
