reluctor ring
Old Apr 26, 2010 | 11:30 AM
southpaw0314's Avatar
Default reluctor ring
im planning on switching my rearend to another 10 bolt that has 3.73 3 series but it is a 4 channel. my car is a 3 channel with a 2 series carrier. are there a different reluctor ring for a 2 and 3 series carrier or are they the same? i called my local chevy dealership to price one for a 3 series carrier but gm has discontinued them.
Old Apr 26, 2010 | 11:38 AM
01ssreda4's Avatar
2 and 3 series have nothing to do with speed sensor rings. 3 and 4 channel is what you need to focus on. A 3 channel has only one speed sensor mounted on top of the center chunk, and a 4 channel has only 2 sensors, one mounted behind each wheel.
Old Apr 26, 2010 | 11:39 AM
01ssreda4's Avatar
https://ls1tech.com/forums/gears-axl...-3-w-pics.html
Old Apr 26, 2010 | 01:51 PM
i have read that thread. i need to add a reluctor ring to the new rearend and since its a 3 series carrier i cannot use my existing reluctor ring. so is this the correct part number 26029185.
Old Apr 26, 2010 | 01:54 PM
FirstYrLS1Z's Avatar
Active Streak: 30 Days
to answer the OP's question,3 channel ABS rearends have 2 different reluctor rings.
for 2 series carriers(GU2)-GM # 26014607,for 3 series carriers(GU5 & GU6)-GM # 26029185.
Old Jul 25, 2010 | 09:28 AM
nuclearmuscle523's Avatar
Youre gonna have to heat that ring up in the oven to get it on.
