4channel rear end help
hello i have a 97 z28 with a 4 channel rear end trac and abs and the rear just went out on me i picked up a 2000 firebird rear end with trac and abs will i have any probs with the traction control system or anything else?
The big difference between TCS and non-TCS rears, is the location of the speed sensor. In a non TCS rear the sensor in on top of the housing. In a TCS rear it has one sensor in each axle end. If your car has TCS and the rear you are swaping in came from a TCS car it should swap right over. However the LS1 brakes and LT1 brakes are different.
