torsen ???????????
Old May 12, 2010 | 09:52 PM
superstu23's Avatar
Default torsen ???????????
i bought a rear end from a 2000 v6 firebird my ? is it has a torsen carrier inside does that mean its posi or still just a open diff?
Old May 13, 2010 | 05:37 AM
FirstYrLS1Z's Avatar
Active Streak: 30 Days
it is a 'posi',came with 99+ Z28,SS,TA,Forms.
Old May 13, 2010 | 08:11 AM
01ssreda4's Avatar
At what point did he say any of those??? He said V6. I wasnt aware any V6 got a posi.
Old May 13, 2010 | 11:22 AM
My main answer was that yes,a torsen is a 'posi' and that it's the one that came with models I mentioned.
Now to increase your 'awareness',2000 V6 Camaros with Y87 Performance Handling Package came with Torsen Limited Slip Differential,fast ratio power steering,large diameter front sway bar,and dual exhaust
Old May 13, 2010 | 04:22 PM
01ssreda4's Avatar
He said firebird
Old May 13, 2010 | 06:52 PM
2000 firebird V6-3800 V6 Performance Package:includes limited slip differential,dual outlet exhaust,P235/55R16 tires and 3.42 axle ratio(3.42 axle available with automatic transmission only)
Old May 13, 2010 | 09:59 PM
dwfronk's Avatar
ok calm down we get the point.
Old May 13, 2010 | 11:24 PM
I'm calm.
Old May 14, 2010 | 12:03 AM
superstu23's Avatar
i calculated the ratio and im comin up with 3.08 gears
Old May 14, 2010 | 12:08 AM
superstu23's Avatar
i put a pic in my profile section i cant get it up as a link for some reson anyways my torsen unit looks just like it except my is a 4 channel with no relucter wheel on it
Old May 14, 2010 | 08:25 AM
01ssreda4's Avatar
^^^looks like every other torsen posi I have seen. Based on a single small picture
Old May 14, 2010 | 11:54 AM
SilverV6Camaro's Avatar
If it's stock it can't be a 3.08. The V6 cars that has posi were either M5's with 3.23 gears or A4's with 3.42 gears. 3.08 were on open rear A4's only, unless the posi unit was added later.
Old May 14, 2010 | 01:56 PM
01ssreda4's Avatar
Coulda been, and for good reason, one wheel peel sucks
Old May 14, 2010 | 04:32 PM
superstu23's Avatar
maybe gm made a mistake the car it was in was a 2000 v6 5 speed car with no obvious modifacations whatsoever but when we pulled the rear it did have numbers writen on it 700100 whatever that means its writen on it multiple times
