need some help with this one guys.
Old May 13, 2010 | 01:01 PM
sscamaross02's Avatar
Default need some help with this one guys.
so i was replacing my axle bearings. i have an 02 ss. there is a diff that uses worm gears i believe and i think this is the torsen rear end? correct me if im wrong. but the peice that slides in the diff to sepeate the side gears seems a little loose. is this a normal situation? the reason i ask is because ive been trying to find a popping noise that seems to be coming from the rear end and i just cant find anything. you can hear it popping at low speeds like 5 to 25. and it doesnt matter if your turning or going straight. i dont seem to hear it if i take a hard turn. any ideas?
its bugging the crap out of me.
thanks!
Old May 14, 2010 | 05:31 AM
DaddySS's Avatar
The thrust plate fits a little loose. If you are talking about what sounds like a rattle, it's fairly common with the torsens. I haven't heard of a solution, I put the GM posi additive in mine for grins to try to stop it and it worked for a few weeks.
Old May 14, 2010 | 03:19 PM
ok but are the wheel in the rear supposed to have play in them? kinda like when your checking for wheel bearings up front. because i jacked my car up and grabbed the top and bottom and pulled and pushed and i can move the wheel a little. is this normal?
Old May 15, 2010 | 12:27 PM
anybody have any ideas? nobody's rear wheels have play in them?
Old May 15, 2010 | 05:55 PM
SS SLP2's Avatar
may have a little in/out, should be none top/bottom
Johnny
Old May 16, 2010 | 06:46 PM
ok so something is wrong. i do have top to bottom on my rear tires. any ideas what could cause this?
Old May 18, 2010 | 05:44 AM
DaddySS's Avatar
Yes. The axle will move out to the limit of the C clip and in to the limit of the plate but that's not what is causing your rattle. I believe it is gears in the torsen with "normal" play but that's a guess.
Old May 18, 2010 | 05:48 AM
DaddySS's Avatar
If you've got the cover off, remove the 8mm holding the thrust plate and remove the plate, remove the caliper bracket and ABS sensor, push the axle in, remove the C clip and remove the axle. Check the axle surface and bearing for wear.
Old May 18, 2010 | 07:43 AM
01ssreda4's Avatar
Johnny
Old May 19, 2010 | 12:51 PM
yea i checked the axles and they looked good. do these diffs just make noise?because i cant find anything.
Old May 20, 2010 | 09:13 PM
ok so while i was driving i found that it seems to make the noise only when coasting. and when ever i put it in gear and put a load on it that the sort of popping, ticking noise goes away. buts its kinda hard to tell for sure due to exhaust. no one has had this problem before?
